I´m trying export the report about "sightDistanceCheck", but in the option:
"Select type file:" only appears the extension "*.xsl" when the format to Excel is ".xls".
I can´t select other extensions and in the "help guide" says that we can choose other formats:
Opcionalmente, cree un informe de análisis de mira. En la lista Elija un tipo de archivo, especifique una de las siguientes hojas de estilo de informe:
This bug is in Civil 3D 2013 Spanish.
Solved by tcorey. Go to Solution.
I have never used these commands but I would export the report and see if,
a. I could open the file in Excel by changing the extension from xsl to xls. Even though xsl is a know file extension perhaps the xsl is a typo...
b. I could simply import the xsl file into Excel.
John Mayo
Hello Joantopo,
The XSL file it refers to is a StyleSheet file that tells the XML generator how to create the file. You will notice if you use the pulldown that there are different XSL files for HTML, TXT, CSV, and XML. Picking the ReportTXT.xsl option creates a report with a TXT extension. The style sheet is always .xsl.
Tim
Great!
I didn´t find the path, and now I´m looking for "ReportTXT" and I have found the path:
"C:\Autodesk\AutoCAD_Civil3D_2013_Spanish_Win_64bit\x64\es-ES\C3D\AllUsersContent\Data\SIGHTC_1"
Thank you.
