Civil 3D Forum
Side walk and Ditch subassemblies issue
4 REPLIES 4
L3GO-Ed
975 Views, 4 Replies
Hello everyone
I intended to create an assembly with a side walk formed fron generic lane and a side ditch. I wanted the ditch to be lined with a material but when I do this, the sidewalk attaches to the bottom of the ditch. Without any material, its correctly attached to the end of the drain. But my design includes lined material in the ditch I would like to be able to calculate the quantities associated with it. How can this be resolved? See attached pics
4 REPLIES 4
Lisa_Pohlmeyer
in reply to: L3GO-Ed
What version are you using? What sub-assembly (name please) are you using to get the depth of material? From looking at it, I would think you could select your sidewalk and rt-click, move to, the desired link point on the ditch. I'm not sure why you're using a lane sub-assembly for a sidewalk though.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
L3GO-Ed
in reply to: Lisa_Pohlmeyer
Hey Lisa,
My choice of a generic link for a side walk was dictated by the design requiring the side walk to be inclined at an angle to the drain, "drainage issues". Otherwise even when I exchange it for the "sidewalk", same problem arises. For the drain am using the "ditch" from "Trench pipes group".
And am running C3D 2014
Lisa_Pohlmeyer
I'm using 2012 and I've tried using your sub-assemblies. I can't get the material area in my ditch to fill, but what I might suggest is that you place the ditch on the assembly without changing any of the parameters. Then add the lane so that you can select the outermost link of the backslope. Then change the parameters of the ditch foreslope and backslope widths and the width of the ditch and see what happens. If you're setting the ditch parameters prior to adding the lane sub-assembly, you might not be able to select the correct link point.
Lisa Pohlmeyer
Civil 3D User
L3GO-Ed
That works fine Lisa. Thanx
Rail Community
