Civil 3D Forum
Side Slope Overlapping Issue
18 REPLIES 18
Message 1 of 19
onsionsi1
1978 Views, 18 Replies
How to solve overlapping side slope issue as in attached file.
I used a conditional cut and fill with link slope to surface.
Any advice will be appreciate.
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
18 REPLIES 18
Message 2 of 19
neilyj666
in reply to: onsionsi1
i think you may have to do some manual adjustments to get this to be correct
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 19
onsionsi1
in reply to: neilyj666
Can we solve this issue by subassembly composer
Any idea will be appreciate
Thank you
Message 4 of 19
mathewkol
When you have 2 different coeridors such as you have (or 2 baselines in the same corridor) this is very common. Daylight grading tools instead of corridor subassemblies in the overlap area will clean up when they intersect.
There is no conditional daylight for grading though so it may be more difficult.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 5 of 19
onsionsi1
in reply to: mathewkol
can you mention stepses how to use  Daylight grading tools.
Thank you for effort
Message 6 of 19
BrianHailey
  1. Create "Corridor A" and target the "Existing Ground Surface"
  2. Create a surface from this corridor called "Corridor A Surface"
  3. Create a new surface called "Corridor B Target Surface"
  4. Paste the "Existing Ground Surface: and the "Corridor A Surface" into the "Corrido B Target Surface" (make sure to do it in that order)
  5. Create "Corridor B" and target the "Corridor B Target Surface"
  6. Create a surface from this corridor called "Corridor B Surface"
  7. Continue the process until you have all your corridors and corridor surfaces created
  8. Create a new surface called "Corridor Final Surface" and paste in "Corridor A Surface" and then "Corridor B Surface" and then "Corridor C Surface" etc.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 19
If you want them to blend without one taking precedence over another, ensure they are in the same site and the gradings should self-intersect.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 8 of 19
neilyj666
and i'd save the drawing before attempting to use grading objects
Message 9 of 19
Joe-Bouza
Are those the same as the ones in the December Playboy? Smiley Wink
Joe Bouza
Message 10 of 19
mathewkol
Matt Kolberg
Message 11 of 19
onsionsi1
in reply to: ericcollins6932
Can you explain in stepses.
Thank you for your advice
Message 12 of 19
fcernst
Omit the crossing daylight links through your Section parameter editor.  See the two pictures below.
This stinks that Civil 3D does not have the intelligence to clean up intersecting Daylighting in Corridors. Especially, when using two Baselines in the same Corridor!
22
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 13 of 19
neilyj666
in reply to: fcernst
The Autodesk BIM dream is still a long way off in Civil 3D I'd say...
Message 14 of 19
onsionsi1
I figure out the best way to do that,
1- Create surface from Baseline 1
2- Create a fetureline form the surface of Baseline 1 that located in the intersection between corridor 1 & 2
3- Create subassembly that target featureline by using linkoffsetandelevation
Any queries will be wellcom
Message 15 of 19
fcernst
I take back my "C3D stinks" on this grading cleanup issue with Corridors. SAC is making me me eat those words.
I created a subassembly in SAC that cleans up intersecting daylight links between two Corridors. You can see below, between two crowned corridors, the daylighting links catch into existing ground, and stay apart up to about Sta 0+70. The corridor on the left is daylighting at 25%, and the corridor on the right is daylighting at 15%.
After that,  they are intersecting and cleaning up with each other.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 16 of 19
onsionsi1
Dear Mr.Ernst,
I will be appreciate if you can send me the .pkt file so that it will help me to reduce a time to produce that corridor.
Thank you.
Sadek
Message 17 of 19
onsionsi1
Dear Mr.Ernst,
Can you explain how you did your template in SAC or can you post your .pkt file here please.
For your advice please.
Thank you.
Sadek
Message 18 of 19
joantopo
My new subassembly (with SAC)
http://forums.autodesk.com/t5/autocad-civil-3d-infraestructura/intertalud-este-subensamblaje-es-la-b...
This subassembly can make a cut slope with multiple slopes (maximum 3 slopes) with diferent slope and maximum delta Y.
Obviously, it can make with fill scenario. ( 1 slope).
It has another parameters such as "no intersection" and you then you can use it independent omitting the intersections. Ideal if you want to use this same subassembly in other parts of the corridor without intersections.
I am talking with Civil+plus to upload it in the cloud and selling for a little price.
Regards.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Message 19 of 19
joantopo
in reply to: joantopo
@fcernst can your subassembly make 3 slopes in cut?
Can make slopes in cut from the Top (Daylight_Cut FL) ?
I would like to have more details of your subassembly to share opinions.
Rail Community
