Distinguished Contributor
onsionsi1
Message 11 of 17 (336 Views)
Re: Side Slope Overlapping Issue
11-26-2012 01:20 AM in reply to: ericcollins6932
Can you explain in stepses.
Thank you for your advice
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Valued Mentor
fcernst
Message 12 of 17 (317 Views)
11-30-2012 06:11 AM in reply to: onsionsi1
Omit the crossing daylight links through your Section parameter editor.  See the two pictures below.
This stinks that Civil 3D does not have the intelligence to clean up intersecting Daylighting in Corridors. Especially, when using two Baselines in the same Corridor!
22
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
neilyj
Message 13 of 17 (310 Views)
11-30-2012 06:17 AM in reply to: fcernst
The Autodesk BIM dream is still a long way off in Civil 3D I'd say...
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
onsionsi1
Message 14 of 17 (277 Views)
12-31-2012 09:55 AM in reply to: onsionsi1
I figure out the best way to do that,
1- Create surface from Baseline 1
2- Create a fetureline form the surface of Baseline 1 that located in the intersection between corridor 1 & 2
3- Create subassembly that target featureline by using linkoffsetandelevation
Any queries will be wellcom
Valued Mentor
fcernst
Message 15 of 17 (235 Views)
01-03-2013 04:14 PM in reply to: onsionsi1
I take back my "C3D stinks" on this grading cleanup issue with Corridors. SAC is making me me eat those words.
I created a subassembly in SAC that cleans up intersecting daylight links between two Corridors. You can see below, between two crowned corridors, the daylighting links catch into existing ground, and stay apart up to about Sta 0+70. The corridor on the left is daylighting at 25%, and the corridor on the right is daylighting at 15%.
After that,  they are intersecting and cleaning up with each other.
Fred Ernst, PE
C3D 2015
Ernst Engineering
onsionsi1
Message 16 of 17 (217 Views)
01-04-2013 11:44 AM in reply to: fcernst
Dear Mr.Ernst,
I will be appreciate if you can send me the .pkt file so that it will help me to reduce a time to produce that corridor.
Thank you.
Sadek
onsionsi1
Message 17 of 17 (175 Views)
01-17-2013 07:30 AM in reply to: fcernst
Dear Mr.Ernst,
Can you explain how you did your template in SAC or can you post your .pkt file here please.
For your advice please.
Thank you.
Sadek
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
