Civil 3D Forum
Sid don't plot with DVIEW screen twist at 270 degrees
8 REPLIES 8
Message 1 of 9
JeffWright5789
399 Views, 8 Replies
Hello All:
anybody find a work around for plotting a MrSid using DVIEW TW 270 ?   Naturally we've spend 2 days on this.  DVIEW used to be a great way to create dynamic views...
Appreciate all the help from the Forum
Version: AutoCAD C3D 2010
8 REPLIES 8
Message 2 of 9
that's not enough info:
  • what version of Civil3D do you have
  • what servicepack
  • what plotter-driver
  • problem also visible while plot-preview is shown
Look to the attachment, this is how Civil3D and SIF-files work at my pc with rotated views.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
Civil 3d 2010.  The plot dialog you show in the attachement doesn't even remotely look the dialog I get when I plot?
Message 4 of 9
I used Civil3D2013 and the plot dialog (except as mine is German) has not changed for some releases now.
>> Civil 3d 2010.
I had more questions than just the Civil3D-version 😉
And I did now try SID-files with Civil3D2010 (D.309.0.0 Version 4.1), it works as designed.
An additional question I have now: have you referenced the SID-files with MAPIINSERT or using the FDO-functionality?
- alfred -
Alfred NESWADBA
Message 5 of 9
I've done the insert with Mapiinsert and used the RASTER attach thru the Map utilities.  My plot dialog must be broke if they didn't change it.
Message 6 of 9
Plot preview only shows line work ...  no sid...
Message 7 of 9
So how does your plotdialog look like? Upload a screenshot.
I'm not sure what "Map utitlities" start to get images referenced (I'm using a German version of Civil3D). But if it's the command _IMAGE or _MAPIINSERT again, then try it with command _MAPCONNECT (that is what I use by default except I have to much data, because MAPIINSERT is faster at all).
BTW: you have tried also one image in a complete new drawing (based on an original template from Civil3D)?
- alfred -
Alfred NESWADBA
Message 8 of 9
thepworth
in reply to: JeffWright5789
a couple of thoughts - is the .SID on a "noplot" layer (been there, done that....)
or, what if you try something like simulating dviewtwist:
1) set ucsfollow=1
2) enable ortho mode & draw a set of axes
3) UCS - 3point - click on 3 points from the axes to rotate the coordinate system
4) turn off ucsfollow
5) set ucs to World
Same effect as dviewtwist, but old school....
Message 9 of 9
JeffWright5789
in reply to: thepworth
If all else fails...   Use a tif...   Good to go....  thanks for all the comments...
Rail Community
