AutoCAD Civil 3D General
Member
secadmin
Message 1 of 2 (189 Views)
Sheetset manager slows down the opening of C3D
189 Views, 1 Replies
06-12-2012 10:10 AM
On c3d 2011, we have noticed a significat chnage in startup time.
We added a new user to the system, so that the support path is 'default'
The startup time will be 30 secs or so with the generic profile,and 45 secs to a minute for the server based profile data we typically use (slow network share).  Reasonable.
However, when we have the sheetset manager open @ startup, it takes 4-5 minutes (with either unnamed or our specific profile).   Also, if you have it not start the SS manager @ startup, and run the 'sheeset' command manually after c3d opens, it takes 3-4 mins for the command to complete.
Member
secadmin
Message 2 of 2 (153 Views)
Re: Sheetset manager slows down the opening of C3D
06-13-2012 07:11 AM in reply to: secadmin
Tested with AV off... No change
Alternate cad profile... No Change
Cleared all Temp files... No change
repaired install... No Change
Logged in as alternate user who had never logged into computer before.
Copied the c:\users\USERNAME\appdata\roaming\autodesk\c3d 2011\enu to c:\ENU-BAK. Logged back in under original user and renamed his ENU folder to ENU-OLD. I then copied c:\ENU-BAK structure back to the proper location
App boot times are now in the sub-30 seconds range.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
