Civil 3D Forum
Sheet print area from polygonal viewport?
17 REPLIES 17
Message 1 of 18
Solefio
796 Views, 17 Replies
I am trying to create two column sheets with a polygonal viewport, but it doesn't seem to work. The point is that I want to use the area above the stamp to be able to fit two columns on one sheet, but the last section in the second column ends up where my stamp is. Is this possible? Is there another way to solve this problem? I'm not to keen on moving the sections by hand, since they keep jumping back.. I'm using Civil 3D 2013.
/Sofie
17 REPLIES 17
Message 2 of 18
troma
in reply to: Solefio
Difficult to understand your question. What is your stamp? Is that relevant? Are you talking about multiple section views? Are you talking about plan production?
Posting a picture of your dilemma may help.
Mark Green
Working on Civil 3D in Canada
Message 3 of 18
Solefio
in reply to: troma
No, it's not relevant what my stamp is, its the shape of the viewport that's relevant. It's multiple section views i'm trying to make. In the picture the cyan shape is the viewport I want, the yellow is the printarea i get (when i make a template with the polygon viewport) and as you can see the last section won't be seen in the final layout as it won't fit in the viewport. Is this clearer?
Message 4 of 18
troma
OK, I understand.
Sorry, I don't know of a solution for you. Hope someone else can help.
Mark Green
Message 5 of 18
antoniovinci
Madame, please sit down comfortably and listen.
There are mandatory 3 rules in this forum:
1] Nothing is impossible for Autocad
2] For Autocad impossible is nothing
Throw away your non-standard polygonal viewports, use a classic rectangular one, then press F1 and learn all about the powerful _WIPEOUT command.
3] Period.
Message 6 of 18
troma
in reply to: antoniovinci
Sofie stated that her 'Stamp' is in that location. I don't know what the 'stamp' is, but I presume it is part of the title block in paperspace. Therefore it is necessary to print the 'stamp' and not obscure it with a wipeout.
Mark Green
Message 7 of 18
Solefio
But a wipout in the layout won't affect my multiple section view template print area, will it? It's the position of the sections I want to change, the polygonal viewport works fine as a viewport, but not in the template.
And yes, by stamp I mean title block. A bit of swenglish there, sorry.
Message 8 of 18
peterfunkautodesk
The program that calculates the number of sections that can fit on a sheet looks only at the overall rectangle and wasn't designed to look at a plot space that would have different settings per column. Your plot space would also have issues if the sections were very wide.
I think it comes down to a couple of factors: extra white space (set the plot space to cut off the whole bottom row) with automated layout vs. reduced white space and saving a few sheets of paper, but your time in moving the sections around on the sheet.
Two other solutions: new title block or a routine that would re order the sections after the initial layout.
Peter Funk
Peter Funk
Message 9 of 18
wfberry
in reply to: peterfunkautodesk
What about being to lock sections in place AFTER they have been moved.  If you can do this now please advise.
Bill
Message 10 of 18
peterfunkautodesk
in reply to: wfberry
The sections don't move after they are placed. If the corridor changes the sections are just updated in place.
Is that the question?
Peter Funk
Peter Funk
Message 11 of 18
wfberry
OK then.  I am pretty sure a couple of yeara ago, sections would "re-organized" themselves.  I have had no need recently with the economy in the "terlit",
Thanks for your answer.
Bill
Message 12 of 18
Solefio
The sections do rearange when you change the Section view group plot style. But once I've decided how i'll do I won't be changing that so ok. Just frustrating when you can do something with a different softwere and not with Civil Smiley Tongue
Message 13 of 18
ceethreedee.com
The sections do Rearrange themselves
If you select a section and right click-> update section view layout.
They will update if you change the scale, or edit the group plot settings..
The sections won;t update though if try and add a new section in.. you can delete sections strangely though.. and it will re arrange..
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Message 14 of 18
Yes,, just tested polygonal viewports do not work...
even though i created a template with polygonal viewport
It still only shows the rectangular frame in model space...
although it doesnt seem to even get that right.. it seems to put all the text from the annotation outside the frame... So it gets cut off when you go into paperspace...
Bug??
Kapanther
Infraworks 2021.1,
ceethreedee.com
Message 15 of 18
mathewkol
Kapanther, this is a different you need to have a data band on the bottom of every section view. Turn off all components so they can't be seen and make the title component on the left. Adjust the sizing until things look correct.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 16 of 18
ceethreedee.com
in reply to: mathewkol
Lol its a good work around... Still annoying that it doesn't sort that out automatically....
Thanks for your help..
Regards
Kapanther
Infraworks 2021.1,
ceethreedee.com
Message 17 of 18
BUMPing this one just to see if someone has managed to solve this most annoying problem.
Template with polygonal viewport for the stampTemplate with polygonal viewport for the stampResult using the template. No regards are taken to my polygonal stamp cutout in the templateResult using the template. No regards are taken to my polygonal stamp cutout in the template
Message 18 of 18
AllenJessup
in reply to: henrik.sjoman
I don't even try to let the program fit the sections. I let them be created in modelspace in just one column and the create two viewports in paperspace to display the ones I want.
Allen Jessup
Engineering Specialist / CAD Manager
Rail Community
