AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 2 (40 Views)
Sheet manager - please help!
40 Views, 1 Replies
01-28-2005 03:13 PM
I'm having a serious problem with my Sheet manager. It happens whenever I setup a viewport in a sheet from my sheet manager - whether I do it manually or by dropping in a named view. If I drop in a view, as soon as it has finished processing, it ignores the view that is set and zooms out to the extents. Also, whenever I add a viewport to a layout, any other viewports on the layout zoom out the extents also. This only happens though when I'm using a sheet in the sheet manager. If I just use the layout tab from my original drawing, both functions work just fine. I realize that there are about million ways that I could set up my sheets differently, especially not using sheet manager, but I really need to be able to use it. Thank you to anyone that can help.
Kevin Currey
Message 2 of 2 (40 Views)
Re: Sheet manager - please help!
02-08-2005 01:57 PM in reply to: kevincurrey
OK ran into this earlier in LDD.
USCVP=0 in paper, model and model through paper. that's 3 times. seems to fix it when you do it in both files, the original the item comes from and the file where it's going too.
Heidi
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
