Distinguished Contributor
jak79
Message 1 of 3 (166 Views)
Sheet Set Manager Override
166 Views, 2 Replies
02-06-2014 02:52 PM
I am using C3D 2014. The question I have is regarding the Sheet Set Manager. Under the "Sheet List" tab when I select my cadd file then select "Publish" the option to "Publish using page setup override" it is grayed out (see attached image). The only work around I know of is to recreate a new sheet set file. Any help or ideas what is causing this and how to fix is is much appreciated.
Jay_B
Message 2 of 3 (156 Views)
Re: Sheet Set Manager Override
02-06-2014 03:11 PM in reply to: jak79
Right Click on the Sheet Set Title>Properties>Sheet Set>Page setup overrides file> browse to the file containing your page setups.
Now you should see the Page Setups.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
jak79
Message 3 of 3 (153 Views)
02-06-2014 03:19 PM in reply to: jak79
That fixed it. Thanks for the help!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
