I'd like to quickly share 3d models with my projects managers on a regular basis.
3DDWF is exactly what I want for this but it just doesn't work (quality is terrible at the highest precision). The next best solution is to to a drive through but you can't record those either. So I'm left with sending them screenshot from the object viewer.
What are others doing?
Can you upload this DWF so we can see what means "terrible quality" for you? (mark the positions that are terrible and if possible show also the source material so we see the original quality).
- alfred -
Navisworks. The designers have Simulate, engineers have Freedom.
You could use Jing (www.techsmith.com) and record screenshots, short videos, etc. and send that out, too.
@randyspear6624 wrote:I'd like to quickly share 3d models with my projects managers on a regular basis.
Theoretically that's what InfraWorks is supposed to help you with. I haven't tried exporting a C3D corridor to it, though.
neilyj (No connection with Autodesk other than using the products in the real world)
It does, albeit with a third-party plug-in. I think with both 3D DWF and Navisworks already being done in-house, letting 3D PDF be farmed out is a good use of resources. I tried 3D PDF a couple of years back and found it glitchy compared to the other options.
Yes, this is the intent. The people i'm sharing it with don't use C3D.
Attached is a typical corridor plot with 3ddwfprec set to 6 and my origin moved closer to the model.
I'm surprised at the array of answers, I started going down the 3ds max road hoping that i could send some sort of video at least but that is a beast in itself that will require more of my time to get up to speed on. I haven't used Navisworks yet but I'll give it a whirl. Autodesk 360 is another possible solution but i suspect they're sharing 3ddwf's there.
If the answer isn't simple and I do need to learn a new program, what do you suggest? 3ds max, navisworks, infraworks?
thanks for the replies so far.
The only one I know of is from Tetra4D. Not sure if they have exclusive development rights or not, as I haven't seen much of anything otherwise. The 3D PDF specs are published by ISO, so its not like its closely held information.
3DS MAX isn't what you are looking for. Its high end visualization software. Use it at the end of a project to create promotional videos for conference booths, YouTube, and future proposals. Like Civil3D, some form of training is required to get acceptable results. Don't have any experience with Infraworks, others can chime in with more detail on that. Looks to be something between DWF and 3DS MAX, for (relatively) quick creation of presentation quality visuals. Navisworks allows you to bring together models from many different sources (e.g. we have projects with piping from several different softwares, structural steel from anther, process equipment from CATIA, and grade from Civil3D), walk around, do some basic measurements, inspect object properties, and so on. It will open 3D DWF files, too (including the free Freedom viewer).
