Civil 3D Forum
Shapefile datum issue
28 REPLIES 28
Message 1 of 29
wsargent
823 Views, 28 Replies
PCPG has just released new data pertaining to Pennsylvania Geology. I am attempting to import the information into my project file that is on the NAD 1983, State Plane Pennsylvania North Feet coordinate system (PA83-NF) but AutoCAD is not reading the datum of the import file. I checked and the PRJ file is with the shapefile and the datum is defined in the file. Any help with this issue is appropriated.
The file can be downloaded here:
http://www.dcnr.state.pa.us/topogeo/openfile/folds.aspx
__________
AutoCAD Civil 3D 2016 SP3.0, built on: AutoCAD 2016 SP1, Map 3D 2016 SP2
Dell Percision T5810: MS Windows 10 Pro; Intel Xeon CPU E5-1620 v3 @ 3.50 GHz, 16.00 GB RAM, NVIDIA K2200 4.00 GB Memory
28 REPLIES 28
Message 2 of 29
antoniovinci
in reply to: wsargent
Instead of _MAPIMPORT that shapefile, try to _MAPCONNECT it, sir.
Message 3 of 29
wsargent
in reply to: antoniovinci
If all my users had Civil 3D that would work, but I have 3 users with Civil and 6 users with vanilla AutoCAD so I need the information as polylines.
__________
Message 4 of 29
antoniovinci
Since your "vanilla" users cannot handle the datum information, why don't you import the shapefile in a Civil pc, and then save it as "normal" polylines for those "normal" Autocad workstations..?
Message 5 of 29
wsargent
The only way I know how to have the information in a form that the AutoCAD users can read is to creat the file using Civil 3D set the working datum and then use _MAPIMPORT to creat the polylines.
With this file the import command is not reading the datum infomation and I cannot get it on the correct datum. Is there a way to use  _MAPCONNECT to bring in the information then convert it to polylines with the shapfile information still imbeded in the lines for the Civil users?
__________
Message 6 of 29
AllenJessup
You didn't specify which file from the link. When I bring in the folds shape is looks like it came in OK. It's centered at  X = 23531.7019     Y = 4829623.3745. I'm not familiar with PA  State Plane so I'm not positive. It's centerd in the state wide PACounty2011_01 file.
Allen
I hit the wrong reply to. Should have been to wsargent
Allen Jessup
CAD Manager - Designer
Message 7 of 29
AllenJessup
in reply to: AllenJessup
This is what my mapimport box looks like.
Allen Jessup
Message 8 of 29
antoniovinci
I guess that WSargent's trouble is the following one:
so try to change the original .PRJ with my attached one (EPSG:32028)
Message 9 of 29
wsargent
That is what mines looks like also. The issue I am having is that the Impute Coordinate is <None>. That filed should have the system that the file was developed in.
I have attached the state boundary for comparison. If you set the datum of the base file to PA83-NF and bring in the boundary you will see that the Impute Coordinate is set to 83LL which is the NAD 1983 lat. Long. Coordinate system. Since the program knows the beginning datum and the end datum it will place the information correctly. With the geologic folds data, since the Impute Coordinate is <None> it is bring in the information centered on the origin, not where I need it.
__________
Message 10 of 29
wsargent
Thanks antoniovinci for your help, unfortunatly your file did not brin the information in on the proper datum ether.
__________
Message 11 of 29
AllenJessup
OK. I'm lost. When I try the state file it shows an input coordinate system of Artic98. I tried looking at the metadata but can't see (quickly) what system these files should be in.
Allen
Allen Jessup
Message 12 of 29
AllenJessup
I've been looking at the Metadata. It looks like it's a NAD27 projection. But Im not sure which one. It looks to be State Wide and none of the State Plane systems listed in Civil 3D are state wide. If someone who's familiar with them takes a look it might solve your problem.
Allen
Allen Jessup
Message 13 of 29
wsargent
I just found out that the PA Department of Conservation and Natural Resources has its own datum that it creates all it's information in... I hate government agencies. Any way, I was provided the below coordinate information and told that I needed to create a new datum in Civil 3D to be able in inset that data properly. Since I don't know how to do that I am back here. How do I create a coordinate system in Civil 3D using this information?
Projection type: Lambert Conformal Conic
Datum: NAD 1927
Spheroid: Clark 1866
Central meridian: -78°
First standard parallel:  33°
Second standard parallel: 45°
Latitude of origin: 0°
Units: meters
Since this is above my current training, THANK YOU in advance for any help.
__________
Message 14 of 29
MMorrison
Hit the create button next to the assign button on the coordinate system panel on the ribbon.  Simply start filling the values in giving it a name that makes sense to you.  It then shows up in the list when you assign the coordinate system.
Martin
Message 15 of 29
Murph_Map
And if you still are lost with Martins reply, here's a link to Sinc's helpful tip on it.
Murph
Supporting the troops daily.
Message 16 of 29
MMorrison
Well, my reponse was hastily typed...I will take all the help I can get.  Thanks, Murph
Message 17 of 29
antoniovinci
It's hard to believe that US government uses a non-conventional EPSG, sir...
Anyway, I advice you to:
1] do everything in your standard PA83-NF
2] from time to time, export your vectors to Google Earth, in order to check the alignment on the physical planet (command _PUBLISHKML)
3] when everything fits, finally convert all to their odd CRS.
Message 18 of 29
wsargent
in reply to: Murph_Map
That is a very helpful video, but unfortunately I do not understand the language of coordinate systems. In the video he shows how to create a Lambert Conformal Conic, single standard parallel; from the information I was provided it looks like I might have a double standard parallel, but I have no Idea. I also cannot figure out where the central meridian goes.
[edit] removed
__________
Message 19 of 29
AllenJessup
This is the coordinate system info from the metadata, if it helps.
Allen Jessup
Message 20 of 29
AllenJessup
I'm not saying this is the correct way to do things. But you're working with state wide data, much of which comes form scanned maps.
You could always cheat. You have the state border in both systems. Move, Rotate and Scale may get you a close enough fit. You wouldn't want to do it this way if you'll have to do it more than once or twice.
Only you can judge if this is appropriate for your project. I'm just going by what I've seen of it.
Allen
Allen Jessup
Rail Community
