AutoCAD Civil 3D General
Message 1 of 7 (219 Views)
Shape Style in Sections
219 Views, 6 Replies
12-21-2013 10:43 AM
I can show calculated volume in my sections if I use methods as "Primordial" or "Average End Area" but not "Composite Volume".
Is that a bug?
Jay_B
Message 2 of 7 (194 Views)
Re: Shape Style in Sections
12-21-2013 12:47 PM in reply to: teflon
If your on 2014 and unable to get Composite volumes from your various corridor shapes, there is a known issue with display and calculation of Material Volumes. See if This thread describes your issue?
Jay
C3D 2012 SP3 & C3D 2014 SP1
Win 7 Professional 64 Bit
Message 3 of 7 (189 Views)
12-21-2013 12:57 PM in reply to: Jay_B
Thank you for replying!
I am using 2012 and 2013 calculating earthwork between two surfaces Existing Ground and Proposed Ground. So no corridor involved.
For two other calculation methods it works fine showing eartwork in sections but not by Composite Volume.
Joe-Bouza
Message 4 of 7 (169 Views)
12-21-2013 02:50 PM in reply to: teflon
Am I off base here? I though composite was grid base making it irrelevant for section comps?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
sboon
Message 5 of 7 (166 Views)
12-21-2013 03:10 PM in reply to: teflon
I've tried this also with one of the tutorial drawings.  Apparently the composite method does not create an end area, so there is nothing to display in the section view.  See this link for more details.  I did find that, even though there aren't any material sections you can still get output in a volume table, so it does actually calculate something.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Message 6 of 7 (155 Views)
12-21-2013 04:08 PM in reply to: sboon
I think this is the answer: Composite volume does not appear in section! I been trying for a long time without any results! Strangely there is no notice about that in any documentation!
Showing volume in section is very helpful because then one would know what is calculated. "Fill", "cut", "Above" and "below" all should be in the right place in order to get the correct result. Taking a look at the sections gives one a hint!
Other issue is that there is no "Tin Volume" so how the Composite Volume is calculated?
sboon
Message 7 of 7 (152 Views)
12-21-2013 04:22 PM in reply to: teflon
The calculation is the same, only the output is different.
Steve
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
