AutoCAD Civil 3D General Discussion
Member
david.mustyak
Message 1 of 5 (727 Views)
Accepted Solution
Setting up custom coordinate system for COGO points
727 Views, 4 Replies
07-10-2012 06:44 AM
Hi!
I have a small field (5 by 5 meters) to be set out with about 40 points. Currently i use EOV (Hungarian National Coordinate System), thus each point has a lot of digits. I want to make the implemetor's job easier, so i want to move and rotate the CS near to my field.
I tried to use UCS, but the COGO points retained the "World" coordinates.
Do you have any idea how to carry out this without moving my whole drawing to the origin?
Thanks!
*Expert Elite*
mathewk
Message 2 of 5 (715 Views)
Re: Setting up custom coordinate system for COGO points
07-10-2012 09:50 AM in reply to: david.mustyak
You can truncate the coordinates.
http://www.civil4d.com/2008/01/truncs-arent-just-for-elephants/
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Member
david.mustyak
Message 3 of 5 (708 Views)
07-10-2012 10:53 AM in reply to: mathewk
Thanks, Matt!
It is a perfect solution for truncating the digits, but i would like to rotate the CS as well, as it is shown below.
I think it can be solved with trigonometric functions, but isn't there an easier way?
Distinguished Contributor
ctbailey
Message 4 of 5 (703 Views)
07-10-2012 11:35 AM in reply to: david.mustyak
I think this is a perfect example of a use for the "Transformation" tab found in Drawing -> settings.
We don't really want to MOVE or ROTATE the points, we just want to change the display of the points.
I would look into the Transformation tab, and then revise some of the labels to use the "grid" coordinates, instead of the "local" coordinates.
__________
Craig T. Bailey, PE, LLS
Bailey Engineering
Member
david.mustyak
Message 5 of 5 (698 Views)
07-10-2012 12:06 PM in reply to: ctbailey
I tried to use the Transformation before but i didn' know about the grid coordinates.
Now it works perfectly! Thanks!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
