Civil 3D Forum
Setting surface materials in Civil 3D
1 REPLY 1
304 Views, 1 Reply
I have been asked to display ground layers for my road design drawing, and wondering if this is possible in AutoCAD Civil 3D. For example, I have designed a road in my model, and there is suppose to be bedrock at 3m below the surface, is there any way to make my cross-sections automatically show where the bedrock elevation will be?
1 REPLY 1
tcorey
If the bedrock is uniformly 3m below OG, copy the OG surface, rename it to Bedrock, then use Raise/Lower Surface to lower it 3m. As long at its surface style has Lines turned on in Section view and you select this surface as a data source when creating the Sample Line Group, the surface will plot with the cross sections.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
