Civil 3D Forum
Set a profile current
4 REPLIES 4
230 Views, 4 Replies
Hello all, I'm attempting to edit a layout profile by moving the pvi. All works fine until I try using the transparent command for station and elevation. It indicates that there is no station as I move my crosshairs around. It works in a different profile so I'm thinking that it should be asking me to select which profile view to use but it is not doing it. Any ideas? -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM
4 REPLIES 4
Aha! I figured out my problem. If the previous profile view is visible, it assumes you want to reuse that view. If you pan so that view is no longer on the screen, it will prompt you to select a profile view. -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM "Brian Hailey" wrote in message news:419a8a98$1_3@newsprd01... > Hello all, > > I'm attempting to edit a layout profile by moving the pvi. All works fine > until I try using the transparent command for station and elevation. It > indicates that there is no station as I move my crosshairs around. It > works in a different profile so I'm thinking that it should be asking me > to select which profile view to use but it is not doing it. Any ideas? > > -- > Brian Hailey > LDT2005 > C3D2005 > XP Pro - SP 2 > P4 2.8GHz > 1.00 GB of RAM > > >
Ok, I take that back. That didn't necessarily work. Back to my original question, any ideas? -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM "Brian Hailey" wrote in message news:419a8b47$1_3@newsprd01... > Aha! I figured out my problem. If the previous profile view is visible, > it assumes you want to reuse that view. If you pan so that view is no > longer on the screen, it will prompt you to select a profile view. > > -- > Brian Hailey > LDT2005 > C3D2005 > XP Pro - SP 2 > P4 2.8GHz > 1.00 GB of RAM > > > "Brian Hailey" wrote in message > news:419a8a98$1_3@newsprd01... >> Hello all, >> >> I'm attempting to edit a layout profile by moving the pvi. All works >> fine until I try using the transparent command for station and elevation. >> It indicates that there is no station as I move my crosshairs around. It >> works in a different profile so I'm thinking that it should be asking me >> to select which profile view to use but it is not doing it. Any ideas? >> >> -- >> Brian Hailey >> LDT2005 >> C3D2005 >> XP Pro - SP 2 >> P4 2.8GHz >> 1.00 GB of RAM >> >> >> > >
I think its bug. I got the same thing. Maris Rubenis "Brian Hailey" wrote in message news:419a8a98$1_3@newsprd01... > Hello all, > > I'm attempting to edit a layout profile by moving the pvi. All works fine > until I try using the transparent command for station and elevation. It > indicates that there is no station as I move my crosshairs around. It > works in a different profile so I'm thinking that it should be asking me > to select which profile view to use but it is not doing it. Any ideas? > > -- > Brian Hailey > LDT2005 > C3D2005 > XP Pro - SP 2 > P4 2.8GHz > 1.00 GB of RAM > > >
Brain and Maris, We could track this problem during "Edit Profile..." command.. Transparent commands during edit/layout profile seems to be remembering the last profile view used, which it should not. Will be addressed ASAP. Thanks Chakri "Robiz" wrote in message news:419b08ba_2@newsprd01... > I think its bug. I got the same thing. > > Maris Rubenis > > "Brian Hailey" wrote in message > news:419a8a98$1_3@newsprd01... > > Hello all, > > > > I'm attempting to edit a layout profile by moving the pvi. All works fine > > until I try using the transparent command for station and elevation. It > > indicates that there is no station as I move my crosshairs around. It > > works in a different profile so I'm thinking that it should be asking me > > to select which profile view to use but it is not doing it. Any ideas? > > > > -- > > Brian Hailey > > LDT2005 > > C3D2005 > > XP Pro - SP 2 > > P4 2.8GHz > > 1.00 GB of RAM > > > > > > > >
Rail Community
