Does anyone know of a way to set the pipe network catalog path using a LISP routine or other script file? We switch between catalogs quite often. It is time consuming to browse folders.
I was hoping for this also.
I suspect you could brute-force it since there doesn't appear to be a command line version of the command "SetNetworkCatalog".
Set the desired settings, export this key, and repeat for each set of settings.
Then import the .REG file as needed.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-Dxxx:xxx\Profiles\<<Profile_Name>>\Preferences\AeccUiNetwork100
Thanks. That looks promising. I posted that question two year ago and had forgotten about. However if the solution in the newer post you linked to works that would certainly be valuable.
