Having several issues.
1. Right click is not popping up menu. Right click customizations are all set correctly. Works fine in plain Autocad.
2. When I select an object the correct layer is not showing up in the AutoCad "Layers" toolbar. That toolbar is only showing the current layer. The correct layer however is showing up the "Properties dialog box" Again plain AutoCad works ok.
3. When selecting objects I need to select my desired command 1st to get the desired results. Example if I window or use the quick select to select my desired objects. For instance if I quick select all cogo points, it highlights them all and I want to explode them or delete, etc, I then hit or type the command. It then drops my selection and tells me to select objects. Sometimes I want to dlete a line or something and I have it selected and hit the delete key on my keyboard. That doesn't work anymore. Also if I hit the erase button or type the command it drops the selected object and wants me to pick that object again.
Numbers 1 and 3 happened to me once last week and a reboot fixed it. No dice today though.
Early last week I got a notice for a Autocad SP1 for 64 was available so I updated that. Not sure if that is what is causing my issues or not.
Anyone?
Todd
Solved by Jay_B. Go to Solution.
Well, don't I feel foolish. That worked and I should have thought of that obvious one. Well it has been one of those days. I am glad I did not yet revert to resetting it back to out the box settings. Thank you.
