Hi!
If I have one layer containing different kinds of objects in different colour, is there any way I can select all those of one color? For example, I have houses in magenta and roads in white but in the same layer. If I mark a house and use Select Similar the entire layer will get selected although I just want to select the houses. Can I do a selection based on the colour they have?
Solved by neilyj666. Go to Solution.
Try using the Quick Select method (should be on right click)
neilyj (No connection with Autodesk other than using the products in the real world)
Excellent
Can you mark the post as a solution as an aid to others in the future (and Kudos is gratefully acccepted as well..!!!)
