AutoCAD Civil 3D General
Distinguished Contributor
csevers
Message 1 of 5 (198 Views)
Selection Box
198 Views, 4 Replies
01-06-2013 03:24 PM
How can I disable the selection dialog box and enable selection cycling? I used to be able to hit shift+space bar to cycle through overlapping lines, I'd like to still be able to do that. I just switched from C3D 2011 to 2012.
Chris Severs, EI
Windows 7 x 64 bit
NVidia Quadro 2000 Dual Monitor
6.00 GB RAM
Intel Xeon W3550 @ 3.07 GHz
Civil 3D 2013 SP 2, Civil 3D 2012 SP2, Civil 3D 2011 V3, Civil 3D 2010 V3
csevers
Message 2 of 5 (196 Views)
Re: Selection Box
01-06-2013 03:31 PM in reply to: csevers
This may or may not be related, but when I'm in paper space my osnaps are going crazy, I'd also like to disable whatever is causing this. See attached screen cap (taken in PS).
Chris Severs, EI
Windows 7 x 64 bit
6.00 GB RAM
Jeff_M
Message 3 of 5 (189 Views)
Re: Selection Box
01-06-2013 04:01 PM in reply to: csevers
It looks like you are over the area blocked out by a clipped viewport. Autocad still sees those objects as if the normal rectangular viewport was in use. SHould it be like this? No, IMHO, but that's the way it currently works.
Valued Contributor
Message 4 of 5 (161 Views)
Re: Selection Box
01-07-2013 06:09 AM in reply to: csevers
Disabling Selection Cycling should be as easy as hitting Ctrl+W it will toggle it off/on as needed.  Or hit the icon at the bottom of your screen (Furthest to the right looks like a crosshair with 2 boxes on top of each other).  For Selection Cycling it will be a little more work, I THINK you can get what you want by setting "SELECTIONPREVIEW" to 3 and "SELECTIONCYCLING" to -2.  of course you enter both those variables without the " ".  Good luck..
tcorey
Message 5 of 5 (150 Views)
Re: Selection Box
01-07-2013 08:51 AM in reply to: csevers
You can still hit Shift+Spacebar if that's what you want. Use Shift+Spacebar to put AutoCAD in selection cycling mode, and then click the left mouse button until the object you want selected is highlighted.
The new selection cycling is an awesome tool, but it can really slow down the movement of your crosshairs so it's not a bad idea to leave it off until you need it or use Shift+Spacebar instead.
Best regards,
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
