AutoCAD Civil 3D General
Valued Contributor
Message 1 of 7 (136 Views)
Section view group labeling
136 Views, 6 Replies
09-05-2013 07:20 AM
I have multiple alignments. When I create a section view group I would like a label at the top or bottom that is the alignment name. I cant find this option and I'm certain it exists! Thanks.
jmayo
Message 2 of 7 (128 Views)
Re: Section view group labeling
09-05-2013 07:51 AM in reply to: charles.neely
Edit your section view style. Go to the Title tab, Click the button with the A and a pencil icon. The text editor appears. Add the Parent Alignment.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Valued Contributor
Message 3 of 7 (123 Views)
09-05-2013 07:55 AM in reply to: jmayo
Thats what I currently do, but I consider it a work around. I want a title for the group of section views if possible. That method puts it on each section. It's better than nothing but I would prefer one group label. Thanks.
Message 4 of 7 (119 Views)
09-05-2013 07:59 AM in reply to: charles.neely
I am not sure if this works with section labels but it works with alignment labels.
hold the control key down and select the label. Go to properties. Set new style.
This is how to change the style of one label within a label group.
that way you can label the first section with the parent alignement name (and maybe the last) and leave the rest as just the station.
IF IT WORKS LIKE ALIGNMENT LABELS AND OTHERS DO
jmayo
Message 5 of 7 (108 Views)
09-05-2013 08:06 AM in reply to: charles.neely
Ok I think you want a label with the alignment name to use as a title for sections? If this is correct use a Note Label and use the same Reference Text component in the note label...
John Mayo, PE
IDSP 2014
Valued Contributor
Message 6 of 7 (98 Views)
09-05-2013 08:14 AM in reply to: jmayo
That's just what I needed! Thanks.
jmayo
Message 7 of 7 (92 Views)
09-05-2013 09:12 AM in reply to: charles.neely
HTH Charles.
John Mayo, PE
IDSP 2014
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
