Civil 3D Forum
Section view Center Line block
6 REPLIES 6
1020 Views, 6 Replies
Hi, Is there a way to put in Section view Style a Center Line Block to
see it automatically on any Section view.
Thanks in advance
Leo
6 REPLIES 6
kcobabe
Why don't you just change the Center Axis linetype to Center?
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Excellent!, but how can I insert the block with flags?, I only could
insert text...
Leo
kcobabe
That part may need to be done manually or with a elevation labelstyle, either way it will not do it automitcally unless it's a band style. Try playing around with the band styles and you may find something that works for you. If you always had a grade break, which almost never happens with a complex roadway, then you could just setup a grade break labelstyle.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
My first thought was to look for a font style that had the flag symbol in it and use it for a horizontal top axis label. No luck.
However, you can use the block you have in a section label. Setup a Major Offset label style with only the block component, anchored tot he , and using the 'Anchor Offset Extension' anchor point. When you use this style set the start and end offset values to 0. (so you only get one of these at the center) Set the Dim anchor values to control its vertical location.
Band styles also have the ability to use a block. You can anchor one to the top of the section view and place the block at the centerline.
HTH
BTW: You can apply multiples of the same type of labels with different styles and settings.
> HTH
It works!, I do it with using bands
Leo
kcobabe
yeah the only way to get it to work automatically would be a band. Anything else would require you to do something extra.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Rail Community
