For some reason, the label styles is not available for all corridor. i have multiple corridor and want to label the grade (%) of a an element. See attached picture.
How do i activate to label features on different corridor
The labels for the Corridor object are controlled through the use of "Code Set Styles."
Your pdf looks fine for the "Change Labels" column where that only controls surfaces.
"Basic" in the Style Column is a Code Set Style, either switch that Style to one you have setup to properly display the labels as you like or copy or edit that code set style to display some labels.
See "Label Style" column on Codes Tab in the Code Set Style.
