I can't seem to add section view labels in Civ3D 2011. I follow the usual procedure, but after I pick a point in the section view nothing happens, all it does is continue to ask for another pick point. Has anyone else had this issue? and more importantly the solution.
Have you check the layers are on that section view labels are going to?
Have you check the label style you are using has the label components turned on?
Are you getting a prompt to pick a second point or you are still at the first point? If it's going to help, this is how it works on my machine: http://screencast.com/t/xyofqhPvmGW
Do you have another dialog opened somewhere?
