I learnt that grid spacing in Section Views/Cross Section Sheets is controlled by the Bottom Horizontal Axes minor tick intervals and Left Vertical Axes minor tick intervals in the Section View Style dialog box(see Capture). If this is true what, then, is the function of the grid spacing settings in the "Plot Are" Tab of "Group Plot Style" dialog box (see the other Capture).
Solved by tcorey. Go to Solution.
You can have the group plot style place the grid lines on a sheet-wide basis instead of per individual profile or section. This would be like plotting on grid paper (remember that?.)
This is an either/or option. You wouldn't use both at the same time.
I'd like to know how the minor tick intervals and the plot area grid details work together regarding the grid spacing in the Section Views or in the plotted cross section sheets. If I enter 10" in the tick interval textbox (Section View Style Dia Box) and enter 0.6" in the plot area details text box(Group Plot Style Dia Box), which entry will influence my grid spacings?
