hi there ,
i Use C3D
In the Multi-Section Creation tool i couldn't find a way to edit or remove Grid Break Labels ,
aslo after creation i could Edit it each indvidual Section but not allover all Sections ?
How i can Editit ? also how ican do soin creation
And why do i feel that the 2012 is Different from 2010 ?
Thankx so much for the help so far
Solved by sboon. Go to Solution.
I could Do it with Select Similar Command , and then i deleted but does any one know how toavoid so in the future ?
Thankx
When you create multiple section views there is a step in the wizard where you can set the styles to be used. One of the options you can select is the label set to be applied. If you don't already have one you will need to create a "No Labels" label set, and then apply it here.
For section views that are already built with the wrong labels you can select one and right click to open the Section View Group Properties and change the label settings.
