AutoCAD Civil 3D General
Valued Contributor
Message 1 of 6 (353 Views)
Section Hatch
353 Views, 5 Replies
09-27-2012 01:08 PM
I have searched the Help fine in Civil 3D, I have searched the tutorials and Knowledge Base online, I have searched the Mastering AutoCAD Civil 3D manual, and I can not fine how to turn on hatching in Section Views. Can anyone shed some light on this subject? I'm currently running Civil 3D 2013.
Randy A. Owens
Southland Engineering, Inc.
Win 7 64BIT
C3D 2013
*Expert Elite*
Message 2 of 6 (348 Views)
Re: Section Hatch
09-27-2012 01:47 PM in reply to: randyowens3203
The onlt hatching that happens in section views is from shapes. You'll need to have a shape sampled such as asphalt or base material. After that, it's just a matter of configuring the shape style properly; don't forget to have the "Section" view direction toggled in the Display tab of that style.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Contributor
Message 3 of 6 (344 Views)
Re: Section Hatch
09-27-2012 01:54 PM in reply to: mathewk
I have set up the Materials List & Quantity Takeoff Criteria, and have run volume reports. I just can't fine how to get to the shape/hatching part of it. There appears to be little documentation about this, at least I have not found it, yet.
Randy A. Owens
Win 7 64BIT
C3D 2013
*Expert Elite*
Message 4 of 6 (339 Views)
Re: Section Hatch
09-27-2012 02:05 PM in reply to: randyowens3203
Attach the file if it's small enough or make it smaller somehow.
Matt Kolberg
*Expert Elite*
LisaPohlmeyer
Message 5 of 6 (310 Views)
Re: Section Hatch
10-01-2012 08:20 AM in reply to: randyowens3203
If you want hatching like the attached pic, it's done through the Code Set Styles
Lisa Pohlmeyer
C3D 2012 SP4, evaluating C3D 2015
Please use "Accept as Solution" if this solved your issue.
Valued Contributor
Message 6 of 6 (306 Views)
Re: Section Hatch
10-01-2012 08:26 AM in reply to: LisaPohlmeyer
I'm actually referring to the hatching based on volume reports, that hatches the cut and fill areas.
Randy A. Owens
Win 7 64BIT
C3D 2013
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
