They blocked my png. I tried a jpg on this.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"John Mayo" wrote in message
news:5994424@discussion.autodesk.com...
When I delete the curve I get two disconnected tangents. You can connect
them anyway you like. Stretching one tangent to the apparent intersection of
the two is just very easy for me.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
"Robert" wrote in message
news:5994332@discussion.autodesk.com...
I'm confused here a little. F
rom what I understand I can remove the curve
using the Edit>Alignment>Geometry, Delete Sub-entity then the alignment will
reconnect automatically, then I can re-add the curve. So why would I need to
osnap connect the two tangents as you describe?
news:5994003@discussion.autodesk.com...
If you have an alignment without the extensions you can also edit the
alignment by removing the curve, use the apparent intersection osnap to
conn
ect the two tangents & re-add the curve. The extensions will show.
I would not recommend this for normal production but when you need them you
can get them.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
news:5993524@discussion.autodesk.com...
Why would I not be able to get my alignment line extensions to show
in my
drawing? The C-ROAD-LNE-EXTN layer is on. The linetype is set to continuou
