I need to scale up about 300 circles (manholes) but i need to hold the center point of each manhole. is there a command for this so i don't have to scale each individual circle?
you can select all of the circles by using the command QSELECT, then the command SCALE and it will scale all of your circles but as far as maintaining their center-points I am not sure....
Select all your circles, go to the properties box and set a new radius for them.
This presumes that you want them to all be the same as each other.
Mark Green
Working on Civil 3D in Canada
I feel the above answers aren't good for the OP:
1] the Scale command needs a reference point, so it won't retain the original 300 centers
2] I bet those manholes have different radius...
A solution would be the following:
1] _MAPEXPORT the circles to polygon shapefile, with full geometric attributes as Object Data
2] open the .DBF in a spreadsheet, and multiple the Radius column according to the desired factor
3] erase all but the X,Y,Z and radius columns
4] save as .CSV file
5] in Autocad, open an empty drawing, and run e.g. "Draw from coordinates" of the magic Cadtools by Glamsen.
If they have different radii I suggest asking on the lisp forum. I'm sure there's a few lisps around that have done this before.
Mark Green
YOu should be able to select the circle and use the properties window, as described above, unless they are a block. Then you can redifine the block with the correct radius.
Surveyor Lee
