AutoCAD Civil 3D General
Active Member
Message 1 of 8 (331 Views)
Scale points and their labels
331 Views, 7 Replies
06-13-2013 06:10 AM
Hello!
So I'm stuck with this issue and pulling my hair out over it. I have a plan I need to be able to print at 1:500 or 1:1000 scale.
On this plan I have COGO points with labels, and a point table to compile all of the point data. When I attempt to create a layout I find that the point marks, labels and table become incredibly huge. From reading other posts I get that there is a trick to setting the scale from the right place, but I remain very confused as to what needs to be done where.
Anyone out there able to help?
Isabelle
Pointdump
Message 2 of 8 (323 Views)
Re: Scale points and their labels
06-13-2013 07:12 AM in reply to: isabelle_dizface
This is a burning topic for me as well. I have searched the Innertubes in vain for someone who can explain scales in C3D from top to bottom.
Dave
Dave
Mohave Valley, Arizona
HP DV7 Laptop
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014
Message 3 of 8 (295 Views)
06-13-2013 11:02 AM in reply to: isabelle_dizface
Check your point style to see if the marker is set to "use fixed scale"?
Valued Mentor
IanMcClain
Message 4 of 8 (288 Views)
06-13-2013 04:04 PM in reply to: isabelle_dizface
Under the Marker tab for your point styles, set the size options to "Use drawing scale" and and probably 0.1" as a starting point for the size. This will render the points at 0.1" in any viewport they appear in and multiply by the annotation scale in model space. If you change the annotation scale in model space they will change size in the model, if you change the viewport scale they will change for that viewport.
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
Active Member
Message 5 of 8 (257 Views)
06-24-2013 01:22 AM in reply to: IanMcClain
Thanks for your help, it worked out ok on friday. However, this morning when I opened up the file again, the scales were once again jumping around in layout... any idea why and how to fix it?
Thanks!
Valued Mentor
Ajilal.Vijayan
Message 6 of 8 (254 Views)
06-24-2013 02:38 AM in reply to: isabelle_dizface
After Setting the Viewport Scale in Layout , you need to do a REGEN to update the Civil3d Labels to show its actual size.
Active Member
Message 7 of 8 (247 Views)
06-24-2013 03:06 AM in reply to: Ajilal.Vijayan
Magic! Thank you!
Valued Mentor
Ajilal.Vijayan
Message 8 of 8 (242 Views)
06-24-2013 03:18 AM in reply to: isabelle_dizface
Glad it helped you !......:smileyhappy:
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
