Is there a way to save the range of colors for different surface elevations to a template so that I can apply the same color-to-elevation scheme to another surface in a different civil 3d dwg file ? I can't seem to find that option anywhere, Please help !
There may be something in the UKIE Country Kit - although I've never tried it
8.5 years further down the road....
this last days I'm making around 40 surfaces...
and still have to manually set all the colors for each of them...
What a terrible waste of time Autodesk!! Please start adding usefull functions and first fix all issues before inventing more things we don't need or want.
I had an idea accepted several years ago to export Civil tables in the same way as regular tables and I'm still waiting for it in the software - I now use a free third party app - perhaps 2021...!!!!!!
There are many, many little improvements that would make the software usage easier for the typical user but these don't really appeal to the marketing wonks whereas Cloud sharing/BIM360 does and can be trumpeted in new releases and to sell new subscriptions. I guess the argument is that a programmable product is provided which allows the user to adapt the software to suit their own area of interest.
I'm not convinced that as many people use this BIM360/Cloud functionality as we are led to believe
Partially an answer to the original post, partly to ease the issues @vandenoosterkamp has with 40 surfaces.
You can save the surface in your template with the settings you desire, in new drawings paste the new surfaces into the template surface to get the same analysis settings (elevation color ranges, etc).
To creating 4multiple surfaces with duplicate settings in the same drawing, using the pasted surface above, copy the surface (select the surface, copy from 0,0 to 0,0) and then delete the currently pasted surface and paste a new surface to have 2 distinct (data wise) surfaces with the same settings.
Not elegant or automated, but will save time and headache.
Hi cwr, thanks a lot for this awesome suggestion!!
I just now did it with copying in the same drawing.
- select both surfaces
- copy them in an empty spot close to the last one
- rename them both
- edit them both
- rebuild
complete color scheme intact!
This sunny day starts fine 😄
Does the uk countrykit have this as an option? And can I install an imperial countrykit on my metric C3D anyway without causing issues?
Don't know what these do but they may of use - located in the Toolbox for UKIE
