Civil 3D Forum
Save Columns of data in Toolspace Vista to stay the same after reopen
4 REPLIES 4
ralstogj
234 Views, 4 Replies
Hi
I have set up parcels with some some userdefine proporties for wastewater modelling and setup the columns of data I want in Toolspace but every time I exit the drawing and return the columns shown and order changes is there a way to save the column configuration so it does not reset each time?
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
4 REPLIES 4
lim.wendy
in reply to: ralstogj
 Hi Justin,
There is some issues with sorting when you you edit via properties palette or the Toolspace Vista. Try using the Panaroma view instead. It will retain/remember the order you made. Smiley Happy
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
lim.wendy
in reply to: lim.wendy
Sorry, I just noticed, there isn't a panaroma window for Parcel. Smiley Sad
Can you post the drawing?
Wendy
Wendy Lim
Customer Value Hub
ralstogj
Wendy
Attached is the drawing file.
I am doing the work in 2012 so have not checked if the same issue is happening in a new version.
Another issue with the drawing is that I can not figure out how to delete unwanted userdefined properties for the parcels it appears that once you create one even if it is not referenced anymore you can not delete it.
Justin
Regards
Justin Ralston
lim.wendy
Hi Justin,
I tested the sorting issue on UDP for Parcel in the latest version of C3D 2015 and it will reset itself once you exit C3D completely. Smiley Sad
It will remember the order if you close the drawing and not exit C3D entirely. The order also came from the original UDP you've created from the settings tab. If you would like the order to be fixed, recreating the list in the preferred order maybe one option. Not sure if this can done via API...
For deleting the UDP, it seemed that if you change the Format, it will allow you to delete. See below:
Wendy Lim
Customer Value Hub
Rail Community
