AFAICT, creating sample lines at a specific increment within a range starting from the start of the range is impossible unless the start of the range is divisible by the increment. This is a defect that needs fixing.
All advice welcome. Meanwhile you'll find me typing in the 93 locations for my sample lines. I believe this is what we made computers for.
Mark Green
Working on Civil 3D in Canada
Mark Green
Hi everyone,
I'd like to get some clarification on this issue.
If you had the option to set the start point for the sample line increment, would you expect the increment to continue from entity to entity, and from region to region? Or, would you want to have the option for the increment to start over at the beginning of a new region or line/curve?
Mark Green
I would expect the increment to hold until the end of the alignment or sample range. I agree it should be independant of any corridor and having the option to restart the increment would be nice.
John Mayo
The ability to start the Interval beginning from the BOP as opposed to current behavior of 0+000 as the interval
starting point.
This way as mentioned previously (when choosing a 15m interval) the first station after BOP will always be 15m
after the BOP.
BOP = 1+000
1+015
1+030
BOP=3+000
3+015
3+030 etc.
The corridor interval frequency behavior may also have to change for such a change to be implemented so the sample line stations would have companion corridor frequency line stations at set interval. (If it's also currently tied to 0+000).
What does BOP stand for? I think you're talking about the alignment reference point, but I'm still wondering about the acronym.
I think when you set an alignment reference point, all stations should reflect increments from that point—alignment labels, profile labels, profile view station annotation, etc.
However, in this specific case of creating sample lines by a range of stations, I would expect the increment to literally increment from whatever station I choose as the start of the range.
The corridor frequency is obviously another question, and I'm not so sure of the answer there. In this job I just set the frequency to 5m so that I would have a corridor line at every sample line location. It would be nice if it was set by either the alignment reference point or some other setting in the corridor properties box.
Mark Green
Troma, You are correct the Alignment Reference point (beginning alignment sta.) is what I mean.
BOP stands for Beginning of project and there are numerous acronyms used for the Alignment start point.
I thought that may be confusing for some after posting.
Hi everyone,
Our team is looking more closely at the sample line increment issue. To make sure we've got the whole story, I have two questions:
Thanks again.
Tim
Mark Green
TimYarris wrote:
- How should station equations affect the increment?
- Does corridor assembly frequency need to use the same behavior (assemblies placed at increments relative to the specified region start - not alignment start)?
Tim
Hi Tim,
Thanks for jumping in on this.
What I would want to see is that the sample lines should fall every [increment] after the nearest major station back (towards the origin). If the distance from a sample line is less than [increment] from the next major station, create a sample line at the next major station and then increment from there.
"How should station equations affect the increment?"
Since the object is to create sample lines based on the major stationing. In the case of station equations the first sample line set after the equality should be the nearest station that falls on ( [nearest major station {Back}] + [increment]) unless a major station occurs within the equality then the first increment station after the station ahead.
So if you have an equality station of 3+042 back = 3+047 ahead. If [increment] is 15 then the first sample line would hit at 3+060. 3+000 + (3 * 15) falls between the back and ahead station. 3+000 + (4 * 15) falls after the ahead station so becomes the first station to get a sample line after the equality station.
"Does corridor assembly frequency need to use the same behavior (assemblies placed at increments relative to the specified region start - not alignment start)?"
In most cases I would say yes. But I like choices and I'm sure there's someone out there who has a reason not to want that. So if it's possible I'd say have the default behavior be to match the sample lines but allow that to be overridden with the every [increment] from 0+000 or from the first station of the alignment. Maybe even an option to specify the exact station. If I'm wishing. I'll wish big.
Allen Jessup
Allen Jessup
CAD Manager - Designer
troma, this can be done:
1) Go to your alignment properties and set your Reference Point Station to a station that would allow the beginning of you sample line range to be 0+000 - ie, if you want to start your evenly incrementing range at 0+130, you could set your Reference Point Station to -130.
2) Create your sample group and set the range to start at 0+000 with, say, 15m increments. Your sample lines are now in the right spot, but not stationed correctly.
3) Select all your sample lines and, in properties, change the Lock to Sation value to False
4) Reset you Reference Point Station to 0+000
(badaboom)
I must say Dave, I like the enthusiasm.
@Anonymous wrote:troma, this can be done:
(badaboom)
Shouldn't that be Bada bing, Bada boom!
I like it. Without actually testing it, I will say this looks like a good method.
I'm gonna wait and see what Tim comes up with, but if I need to do this again soon I will try this out.
Mark Green
