AutoCAD Civil 3D General
Message 1 of 2 (128 Views)
Sample Lines and cross sections
128 Views, 1 Replies
01-22-2013 01:20 PM
I need help...  I have a horiz and vert alignment.  Have sample lines and have cut cross sections.  All is set to automatic rebuild.  I went back and revised my vertical profile and now my cross sections band set (that shows to proposed grade) does not match my profile.  I moved my cursor over the sample line and the elevation that shows up does not match my vertical profile.  Before I go and have to redo my sample lines, what am I missing here?
Message 2 of 2 (121 Views)
Re: Sample Lines and cross sections
01-22-2013 01:58 PM in reply to: trynders
Well... I dont know what I did other than selecting the profiles and things and re-selecting the same surface and it finally took it and changed.  Sooo touchy
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
