Distinguished Contributor
mcloughlin
Message 1 of 15 (217 Views)
SURFACE: points and labels invisible
217 Views, 14 Replies
04-17-2014 06:36 AM
In Civil 3D2014, created a surface. Nice topo contours appeared, but points and their labels are invisible (see appended image)! Point and label styles are the normal styles we use, surface style is the normal style we use (both of which produce visible results in other instances).
What could be hiding the points?
Thanks!
rkmcswain
Message 2 of 15 (206 Views)
Re: SURFACE: points and labels invisible
04-17-2014 07:01 AM in reply to: mcloughlin
When you say "points and labels", are you talking about Cogo Points, surface points, spot labels, contour labels, something else?
Probably some combination of the object layer or layer inside the style being frozen, and/or the entity inside the style being turned off.
Distinguished Mentor
Pointdump
Message 3 of 15 (205 Views)
McL,
I can think of a half-dozen things. Post your drawing so we can have a look-see.
Dave
Dave
Mohave Valley, Arizona
HP DV7 Laptop
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014
mcloughlin
Message 4 of 15 (192 Views)
04-17-2014 07:27 AM in reply to: Pointdump
Responding to Pointdump, I've tried twice to attach the drawing, but sending fails.  It is a large drawing (112 MB), and data are derived from a PNEZD point file.  Perhaps it is too large to attach?  Can I send any other information?
sboon
Message 5 of 15 (176 Views)
04-17-2014 08:34 AM in reply to: mcloughlin
The most common reasons for points to not display:
  • Any layers frozen or off?
  • Point styles set to not display?  It appears that you're looking at the drawing in plan view but if you've changed the viewpoint then the points may switch to their model display settings.
  • Any point groups set to no display styles?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Pointdump
Message 6 of 15 (174 Views)
04-17-2014 08:41 AM in reply to: mcloughlin
McL,
I don't know what the file size limit is on this forum. I'll investigate Google Drive and Dropbox today. I've been wanting to check them out.
Dave
Dave
HP DV7 Laptop
rkmcswain
Message 7 of 15 (163 Views)
04-17-2014 10:03 AM in reply to: Pointdump
Pointdump wrote:
McL, I don't know what the file size limit is on this forum.
Take a look: http://forums.autodesk.com/t5/FAQ-How-To-Using-Autodesk/Attachments-size-and-allowable-file-types/td...
Pointdump
Message 8 of 15 (161 Views)
04-17-2014 10:15 AM in reply to: rkmcswain
Thanks RK! Now I know. I did a search, but I didn't find that one.
Dave
Dave
HP DV7 Laptop
mcloughlin
Message 9 of 15 (156 Views)
04-17-2014 10:41 AM in reply to: sboon
Only one point group thus far, set to the standard point and label styles, which should be visible.  The view is plan.
Jeff_M
Message 10 of 15 (151 Views)
04-17-2014 11:46 AM in reply to: mcloughlin
mcloughlin wrote:
...data are derived from a PNEZD point file.
Were Cogo Points created from this file or was it used strictly for building the surface? If the latter, the points will not show up in the 'normal' fashion.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
