Just FAI (For Autodesk's Information)
Every now and then I'll have a sheet that will not accept placement of another model view from the sheet set manager. (There are usually two or more model views already on the layout). Every attempt will cause AutoCAD to crash. I run recover and audit and the problem persists.
Today I did something differently. I added a new layout, and successfully placed the model view on that layout (I accepted the condition that the layout was not part of a sheet set). Then I went back to the layout I really wanted the model view on and was able to place it without any problem. The significant difference I can see is that I usually have only one layout (I typically delete layouts I don't use which leaves only one layout). It seems to me that having one layout and only one layout while attempting to place a model view on it could very well be the cause of this random crash problem. I have not been able to confirm this yet but the next time I crash trying to place a model view, the first thing I will try is to add a new layout.
what is your SSMSHEETSTATUS system variable set on? Default is 2. Try 1 or 0
Your Name
Your Name
