The site with the "|1" suffix gets created when you insert a drawing into
another with the same Site name. The inserted site gets the suffix so it
doesn't conflict with the one in the current drawing.
I'll have one of the QA guys check out the Move to Site problem, it sounds
like a defect. It should work the way you're attempting.
Glen
wrote in message news:5389396@discussion.autodesk.com...
OK, I actually seem to have figured out the source of the problem... but it
brings up another problem.
The feature lines were on different sites. However, they did not start out
that way! I drew ALL the feature lines on the same site, and I have been
editing the file since last week with no problems.
However, when I installed SP3, Civil 3D seems to have spontaneously created
another site with the same name as one I was working on, only with a "|1"
suffix added to the name. For reasons that cannot be explained by medical
science, about 1/3 of my feature lines "migrated" to the new site, seemingly
at random. 8-0
I've been able to get the feature lines to edit dynamically by making sure
that both lines are on the correct site before starting. Unfortunately, when
I change one of the "migrated" feature lines to the correct site, it removes
it from my proposed ground surface and I have to add it all over again. >8-(
Also, when I select feature lines and use the "Move to Site" command, the
command fails and shuts itself down if I select feature lines on more than
one site. This does not cause Civil 3D to lock up, the command just doesn't
work. Since there's no way to visually tell which feature lines are
"migrated", I can't grab large numbers of feature lines and change them
globally; I have to check which lines are "migrated" one at a time. Major
PITA. >8-(
I guess my problem has changed. Why did Civil 3D spontaneously create a
second site?
