Civil 3D Forum
SECTION SCALES
1 REPLY 1
rcallison
214 Views, 1 Reply
SECTION SCALES
When plotting sections the headwall storm structures are rotated 90 degrees showing the face of the headwall not the side.  How can I rotate the structure in section view.  See example below.
1 REPLY 1
AlmasSuljevic
in reply to: rcallison
Is your headwall part of your assembly or just projected block? If projected, I think you can create a block rotated the way you want it and use it in Section View. You would need to edit Structure Style and change the teh existing structure with your new block.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
