I used SAC to create a simple Lane and Shoulder subassembly with top codes only, but it wont follow the alignment superelevation, i keeps a default slope of -3% throughout the alignment. I have tried to go through previous post on this issue with no luck, Kindly assist me in solving this problem I have attached the subassembly file lane.pkt (zipped)
Solved by KMercier_C3D. Go to Solution.
You need to use your calculated "supa" value when generating point P2 instead of the "pavegrade"
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
@KMercier_C3D wrote:You need to use your calculated "supa" value when generating point P2 instead of the "pavegrade"
It works !!
Thank You
