AutoCAD Civil 3D General
doni49
Message 1 of 19 (227 Views)
SAC: Intersection Point. Point not found?
227 Views, 18 Replies
12-19-2013 07:39 AM
I have a custom SA that I created in SAC 2012.
It has an AuxSurfaceLink (AL1) and an AuxLink (AL10).  Then I have an "Intersection Point" (AP13) that is set to the intersection of these two links.  When my corridor tries to rebuild, I get an error message that AP13 could not be created at station 2+05.
I opened the Section Viewer and see no reason for the point not to be created.  If you look at the following image, it is a screen shot of the section at 2+05.  The white lines are what I drew in there manually.  AP13 should not be a problem.SAC SurfaceLinkIntersection.png
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Valued Mentor
fcernst
Message 2 of 19 (220 Views)
Re: SAC: Intersection Point. Point not found?
12-19-2013 07:57 AM in reply to: doni49
Auxillary Points and Links do not get created in the Civil 3D modeling environment.
Ernst Engineering
Fred Ernst, PE
C3D 2015
W7x64; i7 8gb; Radeon HD 5700
www.ernstengineering.com
MKearney028
Message 3 of 19 (206 Views)
12-19-2013 08:40 AM in reply to: doni49
We need more details, but if AL10 cannot hit AL1 within the surface limits, it will give you that error. Surface links have a hard time with extensions.
So how is AL10 being created?
There may be an error before AP13 that is not allowing the subassembly to continue to be created.
doni49
Message 4 of 19 (194 Views)
12-19-2013 08:48 AM in reply to: fcernst
I know that.  But the SA uses the AuxPoints and AuxLinks to create points and links that C3D DOES create.  The first error message in Panorama says that AP13 was not created.  Then there are several error messages about other points and links not being created but those depend upon AP13.  Once AP13 is works, the others should go away.  And this is ONLY happening at 2+05.  The corridor is 290 ft long and the frequency is set to 5 ft.
EDIT:  Here's a screen shot of Panorama.
Don Ireland
doni49
Message 5 of 19 (193 Views)
12-19-2013 08:49 AM in reply to: MKearney028
I understood that which is why I examined where AP13 should be created.  In the cross section editor, I used the same criteria that I defined the SA to use and manually drew the lines that the assembly should be creating.
Don Ireland
Valued Mentor
fcernst
Message 6 of 19 (182 Views)
12-19-2013 09:07 AM in reply to: doni49
If that white line you drew is AL10, I don't see any surface intersection?
What surface is it suppose to intersect with? Is one of the red lines your target surface?
Ernst Engineering
Fred Ernst, PE
C3D 2015
doni49
Message 7 of 19 (172 Views)
12-19-2013 09:18 AM in reply to: fcernst
Here's a screenshot of the preview window from SAC.  This should help you understand what I'll try to explain.
AL1 is an AuxSurfaceLink with a DEPTH of 2ft.  So in the Section Editor, I drew a polyline on top of the surface and moved it down 2 ft.
AP5 is a point created by going from AP4 (the slope daylight point) and turning 90 degrees (referencing the bottom of the ditch (P17).  Then P16 is the bottom of the material layer below point P17.  This is seen in the previous screen shot as the location where my white line meets the yellow line (C3D created the yellow line correctly).
AL10 is created between AP5 and P16.
AP13 is SUPPOSED to be the intersection of AL10 and AL1.
Don Ireland
doni49
Message 8 of 19 (167 Views)
12-19-2013 09:21 AM in reply to: doni49
Attached is a dwg file with my surface, alignment, profile and corridor.
Don Ireland
Valued Mentor
fcernst
Message 9 of 19 (156 Views)
12-19-2013 09:59 AM in reply to: doni49
Make a version with real points, and let's see where they line up. AP5 may be ending up below the surface offset.
Ernst Engineering
Fred Ernst, PE
C3D 2015
doni49
Message 10 of 19 (149 Views)
12-19-2013 11:08 AM in reply to: fcernst
Nice troubleshooting suggestion.  I'll have to remember that one.
I created a point (P23) with a delta x and delta y of 0 relative to AP5 (basically making it on top of AP5).  Then to make the points stand out, I created two additional points (P22 and P21).  I added links between P22 & P16, P16 & P23, and P23 & P22.  I also made a SurfaceLink (not an aux) on top of AL1.
Here's a screenshot of the preview window with those changes.
After saving and importing the updated SA, here's what the cross section editor shows.  You're right, AP5 IS below the AuxSurfaceLink and even with "Extend Link" turned on, it will not improve.
Now I need to figure out WHY that is.  When I manually drew the line work using the criteria specified in the SA, it works fine.
Thanks for all the help!
Don Ireland
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
