I showed my boss the SA that I recently created. He liked it and wants me to write up a little guide showing what I've learned about using the SAC so far -- I'm the first one in the office that has gone far enough actually try and figure it out.
Following is what I've written to explain how the codes relate to what will end up in C3D. I'd greatly appreciate it if someone would review/critique it.
TIA!
CODES
When you create a Point, Link or Shape (excluding the Auxiliary types), each of them have a “Code” property. This is the code that will appear within Civil 3D and allow you to create feature lines and shapes.
Don Ireland
Engineering Design Technician
I'd add that you can view the current Codes by checking the checkbox in the Preview pane. I'd also differentiate between Codes (which are used in Civil 3D) and Comments (which are notes to yourself in SAC).
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Kati,
Thanks for the advice. I'll do that. And sorry for the delayed response.
Don Ireland
