Civil 3D Forum
SAC- Absolute Value
3 REPLIES 3
klugb
1752 Views, 3 Replies
SAC- Absolute Value
Is there a way to get the absolute value using the subassembly composer? I was checking the elevation difference between two points and just want the delta regardless if it's positive or negative.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
3 REPLIES 3
KMercier_C3D
in reply to: klugb
Try: math.abs(p2.elevation-p1.elevation)
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
klugb
in reply to: KMercier_C3D
Thanks!
Tried the "abs" but forgot the "math."
Bruce Klug, P.E.
Civil 3D 2023.2.1
peterfunkautodesk
in reply to: klugb
There is a link in the help file to the Microsoft site that lists all the functions in the .NET Math library. You can use all of these inside of SAC. However, if you think you need trig functions you might want to revisit the point options and intersection options. I don't think I've needed to use trig yet.
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Rail Community
