Hi friends,
How to open subassembly designed in SAC 2013 in the SAC 2012 ?
Thanks in advance.
Solved by KMercier_C3D. Go to Solution.
Subassemblies are not backwards compatible. If you want to use something in Civil 3D 2012 and/or SAC 2012 then it needs to be originally designed in SAC 2012.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
