It comes up 00 15' 7" short when you do the rotation I mentioned in my previous post. I thought also this might have something to do with rounding since you can rotate a line 90 degrees and it comes out right, just when you do an angle in between. This doesn't seem right though, when I use Terramodel and rotate a line the same way it leaves me with a line matching the correct bearing, civil 3d does not do this the way I currently have it setup. Thanks for replying, if anyone can think of what I may be doing wrong or if you can recreate what I am talking about, let me know. You should be able to get the correct bearing just by rotating a line with the angle between the two lines.
