What can I do to show intersection information in a profile label?
I mean, supose I have two roads (A and B)... what should I do to show in the road A vertical profile the name and the station of road B in the properly position of this A profile?
example from a similar post (pdf attached):
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/LABEL-INTERSECTION/m-p/2669277/highlight/true#M129377
Thank you a lot,
Thanks for your reply, Matt.
And how can I insert a block in the intersection? Should I do it manually or set it by some alignment or intersection style?
Of course I already have an intersection object set but maybe this is not what you are talking about ...
Thanks again and I hope solve it 🙂
That what I was afraid of...
Later I'll try do it dynamic with visual basic 🙂
I share your wish. Thanks!
There is a tool that we have developed that might help you. here is a youtube vid of how it works.
https://www.youtube.com/watch?v=5ir8NzL6Uhs
Company website: www.ran-pack.com
Hello, thanks for your reply.
I saw your video and it is interesting but, if I got it correctly, it isn't dynamic, no?
We are working in a project with dozens of alignment and we would like to analyse them dynamically. I mean, for each change we make we would like to show the intersections labels and highlight errors at the profiles and plant.
We are trying to develop a code to do that.
Thanks lot,
Still not possible in Civil 3D 2017. This could all be solved if they allow alignments to be added to profile views. Or even allow "superimposed intersection point" as a marker option in the profile style.
Very frustrating
I just superimpose the adjoining profile into the profile view I want to label and it shows the exact connection point.
I was having the same problem, I am kinda doing what Matt says, but instead I create a point in the intersection and project to my profile view. You can then select for the point to be linked to your vertical profile and on your projected objects label you then create a label with the source station of your point and elevation of projected object. It's not the station from the crossinge aligment, but at at least gives you the elevation and it updates as you change the profile.
Check this video prepared by Mr. Jeff Bartels https://www.youtube.com/watch?v=2qZ3nC-gL1M&index=2&list=LLmNTCUnY6E4VwxfNFJDPDCw
you will have a great idea about labeling the intersection.
i think the same will be applied for profile view labeling
best regards
