AutoCAD Civil 3D General
Valued Contributor
Message 1 of 3 (263 Views)
Reverse "Unlock in drawing" command
263 Views, 2 Replies
11-28-2012 08:34 AM
When I first created my surface model, any point I moved would snap back to its original position like a rubber band.  I had to do some edits so I unlocked this by .... Survey Tab>My survey database>Survey Points>Points,  and then picked "Unlock In Drawing".  This command unlocked All points in the drawing so I could edit them.
 Now that I am done with my edits, how do I reverse this command globally, so as to get  ALL points locked again (so they snap back to their original position like a rubber band if moved, like before) ??
tcorey
Message 2 of 3 (255 Views)
Re: Reverse "Unlock in drawing" command
11-28-2012 09:53 AM in reply to: sswanson
This depends on where you want to points to live.
If they belong in the Survey database, you will need to create a Survey Import Event. When you told it to Unlock in Drawing, that disconnected the drawing-based version of the points from their Survey database counterpart. You moved things around, but the Survey database has not updated. Hence the need for the import event.
If you want the points to be drawing-based and not tied to the survey database, just leave them be, but on the Prospector tab right click Points and select Select. Move to the drawing screen, right click and select Lock Points.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
Message 3 of 3 (227 Views)
11-29-2012 12:05 PM in reply to: tcorey
Thank You Tcorey
                 Steve
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
