Civil 3d reminders,
I downloaded the FlipPipe.dvb file from the link you provided, but when I run the macro it gives me a message
"Compile error in hidden module: ExcelFunctions"
I am using Civil 3D 2013 when trying to run the macro.
I tried to get into the code to see if I could identify the problem but it was encrypted. Have you updated the code? Would it be possible to get a copy of the code? I noticed you had some code samples on your blog, but I couldnt find this particular macro. Thank you so much for any help you can provide.
Does anyone have a .dvb or .lsp for an updated reverse linetype or flip pipe for pipe networks and pressure pipe networks? The one here is not working.
Thanks in advanced.
Wondering the same thing. I get the "compile error" and something about Excel. Using C3D 2020 64 bit and have Excel 2013 installed as part of Office.
Is there a modern example of properly fixing this issue? By way of a "plan readability" or similar scenario?
