Civil 3D Forum
Retaining walls- Please help
6 REPLIES 6
MK2012
2079 Views, 6 Replies
hi everyone,
can anyone told me where is my mistake in making the retaining wall?
i attached here the screenshoots.
this retaining wall is made using a subassembly not using feature line.
Tags (1)
6 REPLIES 6
Jeff_M
in reply to: MK2012
Not sure what the problem is, can you describe what you are expecting vs what is shown in the image?
owenmull
in reply to: MK2012
As Jeff said, I'm not totally sure what the problem is. Looks fine to me. Could you post another image, perhaps detailing exactly what your retaining wall is/isnt doing correctly?
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
wfberry
in reply to: owenmull
I'm guessing that he wanted the vertical face to be exposed.
Bill
MK2012
in reply to: MK2012
hi all,
i made the road corridor using a basic assembly but when i added the retaining wall subassembly the wall shown in the realistic view as sections not as a real wall.
the codes are applied in the code style as shown in the screenshoots.
owenmull
in reply to: MK2012
You've got your links coded, what about your shapes? Are they coded correctly, and set to display?
-Owen
Windows 7 x 64 bit
Civil 3D 2017
MK2012
in reply to: MK2012
Can anyone attach a DWG file of a subdivision of lots including building retaining walls?
I need to compare the codes and parameters with those i used.
Rail Community
