hi everyone,
can anyone told me where is my mistake in making the retaining wall?
i attached here the screenshoots.
this retaining wall is made using a subassembly not using feature line.
As Jeff said, I'm not totally sure what the problem is. Looks fine to me. Could you post another image, perhaps detailing exactly what your retaining wall is/isnt doing correctly?
hi all,
i made the road corridor using a basic assembly but when i added the retaining wall subassembly the wall shown in the realistic view as sections not as a real wall.
the codes are applied in the code style as shown in the screenshoots.
You've got your links coded, what about your shapes? Are they coded correctly, and set to display?
Can anyone attach a DWG file of a subdivision of lots including building retaining walls?
I need to compare the codes and parameters with those i used.
