Civil 3D Forum
Retaining walls- Please help
6 REPLIES 6
2105 Views, 6 Replies
hi everyone,
can anyone told me where is my mistake in making the retaining wall?
i attached here the screenshoots.
this retaining wall is made using a subassembly not using feature line.
Tags (1)
6 REPLIES 6
Jeff_M
Not sure what the problem is, can you describe what you are expecting vs what is shown in the image?
owenmull
As Jeff said, I'm not totally sure what the problem is. Looks fine to me. Could you post another image, perhaps detailing exactly what your retaining wall is/isnt doing correctly?
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
wfberry
in reply to: owenmull
I'm guessing that he wanted the vertical face to be exposed.
Bill
hi all,
i made the road corridor using a basic assembly but when i added the retaining wall subassembly the wall shown in the realistic view as sections not as a real wall.
the codes are applied in the code style as shown in the screenshoots.
owenmull
You've got your links coded, what about your shapes? Are they coded correctly, and set to display?
-Owen
Windows 7 x 64 bit
Civil 3D 2017
Can anyone attach a DWG file of a subdivision of lots including building retaining walls?
I need to compare the codes and parameters with those i used.
Rail Community
