I am having a trouble of creating a retaining walls ,I need the retaining wall to support the roadway i.e. the corridor must run behind the stem. I am filling behind the retaining wall between the embankment and stem to elevate the roadway.plz help
We need more information. Is this wall supposed to be parallel to the road alignment or separate? Can you post a section?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Good day!!
This wall follow the road alignment. please find the attachment.(Horizontal alignment, Section, Retaining wall details )
Thank you
Unathi
Joe Bouza
It appears that you already have the wall designed in detail. It's hard to be sure but it seems that your wall has bends where the alignment uses curves so they won't be parallel all of the time.
What is your goal here? Do you want to model the excavation and backfill required for installation of the wall, or do you want to ignore it and just design the road structure to be built after the wall is in place?
Steve
